cupoftea
Advanced Member level 6
Would you agree, that if hand soldering components, then having the solder resist covered copper plane just 0.15mm away fron the rest ring of a PTH pad (different net) to be soldered is too small for hand soldering? The solder resist would get melted up and could cause opens?
Or, would you agree that there could be shorts from pad to copper plane, even though the plane copper is covered in solder resist?
