0-10Vref DAC controlled voltage&current regulator 0-30V
cyw1984
Member level 2
Member level 2
dac-controlled regulator
anyone have some information about DAC controlled linear voltage & current regualtor???
My current circuit uses the LM358 with 0-10V DAC controlled
but it is too simple......
the output is not linear and very not stable.....
and connect the load...the output will drop a few voltage.
thanks
regulator 0-30v
LM358 is not good choice for 0-30V operation, especially at the low-volt region ..
Better option will be CA3140 ..
If you want you can post your circuit for review ..
Also, see posts on similar subject at:
Regards,
IanP
