weber
Newbie level 3
here is my drawing;
i design it to use as soft start for my smps step down converter.When i connect my smps to 60v battery, it is exploding by %20 probabilty(some of ic exploding then output of smps becomes short circuit because of these ic ,after smps fails). When i connect a ntc to input, it is not helping after warms up.
I want to use this circuit for maximum 1A and maximum 70 v input.
Before make it, i want your comments on this circuit.Part numbers are not cruical. My be i can eliminate D5 that is between D2 and C1 so it can be work also as a soft shutdown.
here is my drawing;
