ĐOT-MǞTRIX Display Programming
Eshal
Advanced Member level 1
Nowhere :)
Hello experts!
I have this schematic attached below,
I have picked this circuit diagram from **broken link removed**
I want to glow just one LED on this display. 1st row and 1st column LED i.e the most upper leftward LED.
What code should I burn in the AT89C51 in Assembly Language to glow it?
Thank you very much.
Why not anyone help me? Does no one know about this?
Regards,
Princess
I do not know the AVR, but ... try this:
- write to the HC164 the value 0b10000000 (0x80, one 'one' and 7 'zero', using 8 clock pulses) and write 0b01111111 (0x7F) to the P0 port. But it depends on the matrix connections (polarity).
Reactions: Eshal
    Eshal
Yes you are right sir.
And let me know if you know how to generate two waves through the programming simultaneously? Using assembly language?
