sunrise264
Newbie level 5
- Joined
- Jan 31, 2018
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 134
There is a paper entitled the working principle of high-power adjustable switching power supply and mentioned a new design of high-power adjustable switching power supply which using Buck-type switching power supply topology, with a single PWM output, MC33060 as a control IC, and dual output IR2110 driver chip and then designed a high-voltage high-power switching power supply as an effective solution to adjustable high-voltage switching power supply circuit, which can solve the problem effectively that in the non-isolated topology, the common switching power supply can not reach high limits, and attached with over-current protection usage.
But my question is what about medium and small power devices? What is the bottleneck for medium and small power devices to increase their frequencies of switching power supply?
In the premise of meeting the efficiency of design requirements, we may blame the main power loss on switch and transformer, another book about switching power supply design mentioned the switching loss is mainly divided into switching on & off loss, charging/ discharging loss, gate-drive losses and so on. Because of the gate charge and discharge loss is not small, what if we use the technique of softswitch to get a ZVS one, which is also called zero voltage switching?
Compared to the current kind of switches, the gate charge and discharge losses are actually not significant considering meeting the voltage and current stress of other Losses, and transformer losses could also be better solved finely coupled by the primary and secondary sides, or using planar cores to reduce losses. In summary, currently, let’s say fly-back 500kHz's, it is difficult to pursue, what are the bottlenecks to making the fly-back 500kHz's ?
