Mithun_K_Das
Advanced Member level 3
- Joined
- Apr 24, 2010
- Messages
- 899
- Helped
- 24
- Reputation
- 48
- Reaction score
- 26
- Trophy points
- 1,318
- Location
- Dhaka, Bangladesh, Bangladesh
- Activity points
- 8,254
I was trying to measure the voltage across R1 which is floating. In simulation it works fine. But in practical, the output is always high. I tried reducing resistor values of R5 & R7. But there is always a offset voltage of 0.7V in the output of Op-Amp. Is this op-amp fault?
which type of op-amp I need to use in this case?
