tony_lth
Advanced Member level 5
- Joined
- Jul 28, 2010
- Messages
- 2,098
- Helped
- 377
- Reputation
- 756
- Reaction score
- 369
- Trophy points
- 1,363
- Location
- Beijing
- Activity points
- 12,727
Hi, All,
For switch on/off RS232 signals, I used CD4066, and because my control signal is TTL level, I have to use CD4054 to convert 0V/5V TTL signal to +5V/-5V signal to control CD4066 On or OFF.
But unfortunately, the circuit doesn't work, and the total current is about 0.8A and CD4054 is fired.
I wonder what's the reason for the burn CD4054?
1. Is it because that CD4054 GND is nor directly linked to main GND, in fact, through a think wire about 10mm length? I think RS232 is very low freq, maybe this is not the root cause.
2. Is it because that STR4/STR1 directly linked to +5V? Should it be by a 10K?
3. Other comment?
many thanks.
Best,
Tony Liu
3. Other comment?
many thanks.
Best,
Tony Liu
