kenambo
Full Member level 6
Hi All,
I set up a circuit to check sp analysis in cadence. I m having 2 ports with one port has 50 ohm and another port has 100ohm. I connected these two ports together.While I am doing SP analysis, I got the following results.
S11 = S22--> 333.33m
S12=S21 --> 942.809m
How S12 is calculated in the above case. I couldn't find any formula reference for the above values.
Can anyone tell me how spectre determines these values?
Thanks.
Thanks.
