AC RMS voltage measurement circiut
francis29
Member level 5
Member level 5
India
I want to measure the AC line voltage with circuit.
Output should be DC so that i can connect it to microcontroller.
this was discussed many many times here in this forum and a lot more often in the whole internet.
No question, no specifications... What do you expect?
* Use the "simialar threads" in the box below
* use the search function of this forum
* use a internet serach engine
* give specifications
* Read some forum posts, articels, documents --> then ask a dedicated question
Klaus
Input is 230V AC 50Hz. How to convert it to voltage range of 0-3.5V DC to read by microcontroller.
