[SOLVED] What is this connector called?
bobsun
Full Member level 2
Full Member level 2
I found a connector below, which allows using screw for fastening, particularly convenient if frequent attach/detach are required.
However, I don’t know the formal name for this type of connector so cannot search it on the net.
Does anyone know what it is called?
Bob
Reactions: bobsun
    bobsun
thylacine1975 and Santosh13,
Wire-to-Board connector seems to be the best name and returns most results. Thanks.
Bob
