campus189
Member level 5
- Joined
- May 7, 2011
- Messages
- 84
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Tennessee,USA
- Activity points
- 1,940
If I were to use these two together with a 12V Car Battery out of the vehicle, do you think this would work ?
The Power Inverter connected to the battery & Battery Charger would be plugged into the power inverter & the battery charger connected to the car battery...
Basically a loop..
I would then use just a couple CFL'S in my house in the event of a power outage.. ( Maybe more than a couple, Don't want to overload the thing)
We lose power a lot in the winter here. This would be used to run Compact Fluorescent lights only..
The battery charger draws 3AmpsX120Volts=360Watts
Which leaves me with 1140 Watts to run at least 4-5 CFL'S in the house for when the power goes out..
In the picture it states 75Amps on label, but thats just to jumpstart.
Heres the information and Technical specifications on both of them...
Battery Charger Information
Technical Specifications
Inverter Information
Basically a loop..
