TACAMO
Newbie level 3
Hi, I have a 28800uf capacitor bank charged at 400vdc that I need to discharge fast. I was thinking of using a MOSFET to switch it. The source pin would go to the negative, the drain pin would go to the load, there would be a 100k resistor between the gate and source. 5 volts would be sent to the gate pin to "trigger" it. Would this work?
