raihanreza
Junior Member level 2
hi
i am trying to do some simulation in CST . but when i try to use FSS template which automatically set up floquet port in zmin and zmax. but when i try to run the simulation it shows that it can not run the simulation as it contains disprsive material at zmin and zmax. how i can shift the floquet port to nodispersive material. the substrate and the patch both are dispersive.
