MAX3421 as a host withy PICAXE
DrWhoF
Advanced Member level 1
I need to read USB keyboard codes.
I have MAX3421 ev-kit and I'd like to write a code that will allow to detect and configure keyboard and then read codes for pressed keys.
So far I can read registers and write data to registers using half-duplex bit banging SPI.
Does anyone have experience with the MAX3421 working as a host?
On the 3421 ev-kit card I can see the bus-power-switch.
It is controlled by GPOUT7.
Start with setting the GPOUT7 = 1.
That should switch the power to the USB connector and set the FLAG on GPIN0 low.
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
I write extensively about max3421e programming here -> Circuits@Home . Look for USB Host Shield. There is a lot of sample code, too.
Unfortumatelly all that stuff is in C and I am not "C-MAN"
---------- Post added at 07:35 ---------- Previous post was at 07:34 ----------
:wink:
IanP
Yes, I can do that.
What would be next?
Reactions: IanP
    IanP
Try to set the MAX3421 as a low-speed host
Which registers have to be set-up?
Reactions: IanP
    IanP
Set the following bits in the R27 register:
DPPULLDN - R27, b7
DMPULLDN - R27, b6
LOWSPEED - R27, b1
HOST - R27, b0
In other words, try to send 0xC3 to R27
Then issue a USB bus reset by setting BUSRST - R29, b0 --> wait something like 100ms and turn on frame markers by sending 0xCB to R27 ..
Now, clear bit FRAMEIRQ and at this stage MAX3421 should generate one SOF packet.
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
Ok, the issue with the MAX3421 is solved, and I can set/read/reset all registers.
So I set it up into the low-speed-host mode, then I set the device address using SUDFIFO. **Next I sent to PERADDR 0x01 – device=keyboard, and so on ..
In an endless loop I send an IN token to EP1, read bits HRSLT0-4, if=0x00 success, and so on, ...., and so on ..
I could read USB keyboard’s press and release codes ..
Fine.
I tried another keyboard.
The same as above.
I tried another keyboard = nothing works.
Keyboard is OK when plugged to a PC.
When I try to send address to it (step **) it returns 0x0D, that is J-state, should be 0x00 => ACK.
So, I’m stuck here and at this moment have no clue what to do next.
Q: keyboards suppose to be low-speed devices. Is it possible that not all are?
Reactions: IanP
    IanP
It doesn’t look like you have performed full enumeration and the USB Enumeration is the process of detecting, identifying and loading drivers for a USB device ..
Some keyboards may respond without full enumeration, some may not .. it's difficult to predict a device's behaviour when you try to make a short-cut ..
Have you tried more keyboards and is that one that didn’t work somehow different from the others?
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
