hactic
Newbie level 5
Hi, I have a basic question about the use of timer 0 in an ADC example code from Microchip.
Here's the code:
My Question:
1. What is the timer 0 used for in here?
2. Why clear PORTB immediately after loading it with some data?
Thanks for your help.
Here's the code:
;* TUT452.ASM
;* Microchip Technology Incorporated
;* 17 March 2003
;* Assembled with MPASM V3.20 and MPLINK v3.20
;* This program configures the A/D Module to convert on
;* A/D channel 0 (the potentiometer) and display the
;* results on the LEDS on PORTB.
list p=18f452
; Include file, change directory if needed
include "p18f452.inc"
; Start at the reset vector
Reset_Vector code 0x000
goto Start
; Start application beyond vector area
code 0x002A
Start
clrf PORTB ;Clear PORTB
clrf TRISB ;PORTB all outputs, display 4 MSB's
;of A/D result on LEDs
movlw B'01000001' ;Fosc/8, A/D enabled
movwf ADCON0
movlw B'00001110' ;Left justify,1 analog channel
movwf ADCON1 ;VDD and VSS references
movlw B'11000111' ;TMR0 prescaler, 1:256
movwf T0CON
Main
btfss INTCON,TMR0IF ;Wait for Timer0 to timeout
goto Main
bcf INTCON,TMR0IF
bsf ADCON0,GO ;Start A/D conversion
Wait
btfss PIR1,ADIF ;Wait for conversion to complete
goto Wait
swapf ADRESH,W ;Swap A/D result nibbles
andlw 0x0f ;Mask off lower 4 bits
movwf PORTB ;Write A/D result to PORTB
clrf PORTB
WaitPush ;Pause while switch is pressed
btfss PORTA,4
goto WaitPush
movwf PORTB
goto Main ;Do it again
end
My Question:
Main
goto Main
bcf INTCON,TMR0IF
clrf PORTB
