In a flyback converter, all current is magnetizing current, so it will flow in both windings.i mean when a primary fet turns off, the magnetising current is flowing and cannot just go to zero..............but if it keeps flowing in the primary, then there will be a resultant current flow in the secondary.....................but i thought magnetising current only flows in one of the windings, ie not primary and secondary at the same time.....so does it all revert to the secondary?
