kg300
Member level 3
- Joined
- Sep 21, 2007
- Messages
- 67
- Helped
- 62
- Reputation
- 124
- Reaction score
- 67
- Trophy points
- 1,308
- Location
- RY Khan - PAK
- Activity points
- 1,852
Hi, this is a SMPS charger based on uc3842 chip and deliver 12V 8A output. the problem is that the supply voltage of 3842 VCC are oscillating and i couldn't fix it at 16V and supply cannot start because 3842 ON volt are 18V. when I remove the chip from circuit it goes to 18V accurately. I tried without transformer but Vcc are not ok. Do it work only with the startup circuit (a resistor connected to the 300VDC)? I change 3842 twice but the problem is same. anybody solve the problem.
Thanks.
Thanks.
