Where to by a dynamic mic
zerodegreec
Junior Member level 3
Looking for source to buy some dynamic mics. All I find on Mouser and the like are Electret mics. I am not looking for a stage mic, just the component. What am I doing wrong in my search?
They are hard to find. The manufacturers show up but seem to be aligned to sell to OEMs only. You can get a complete dynamic microphone for less than $10. The Nady SP-1 and similar products from Sony and Audio-Technica are widely available. Most of the wired microphones made for old cassette recorders and kids karaoke machines are dynamics so you might do well at a thrift store.
Sony FV100 Omni-Directional Dynamic Microphone : Microphones | RadioShack.com
RadioShack Universal Cassette Recorder Microphone : Microphones & accessories | RadioShack.com
If you don't need hi-fi then you can use a speaker or headphone element.
It's practically the same thing as a dynamic mic. A coil close to a magnet.
However the mic resistance is 100 to 1000 ohms, whereas speaker impedance is typically 4 to 50 ohms.
The amplifier circuit will be different. Here's a sample.
www3.telus.net/chemelec/Projects/Spkr-Mic/Spkr-mic.htm
A search should turn up schematics using an op amp, if that would be preferable.
Thank you very much aduiomik exactly what I am looking for.
After your thread with problems with Electret capsules, am guessing this might be for your Rally Car helmets;-)
If you still get instability/feedback problems, double check that you have the common return (ground) wire connected correctly as in your diagram in the other thread.
Also there is a possibility of acoustic feedback when the helmet is not being worn as there won't be much to stop the microphone picking up the earpieces.
good luck
Mik
