[SOLVED] LCD - CGRAM and LCD graphic datasheet
vishy71
Full Member level 2
Full Member level 2
Iran
Hi
I wanna show some characters which I have create them with LCDCC.now I wanna show them on LCD(character LCD).
I know I must save codes in CGRAM(yes?) but how and then how I can show them on LCD?
I can show them on LCD with basic and proton but I wanna do this with assembly.I can use LCD with assembly but I don't know how can I use from
LCD's CGRAM.
my another question is about graphic LCD.is there any body that can give me datasheet for this LCD.I have some but they are not complate.
thanks thanks and thans:-D
What is the controller chipset of your LCD?
The following is a short LCD assembly program which demonstrates the use of CGRAM for storing custom characters:
 title  "Animate - Draw the 'Walking Man' on an LCD"
;  This Code Uses the two wire LCD interface to draw a
;   walking man using User Defined Characters.
;  Hardware Notes:
;   Reset is tied directly to Vcc and PWRT is Enabled.
;   The PIC is a 16C84 Running at 4 MHz.
;   PortA.0 is the Data Bit
;   PortA.1 is the Clock Bit
;  Shift Data:
;  Bit 1 - Always High (Gate for "E")
;  Bit 2 - RS Bit
;  Bit 3 - LCD D4
;  Bit 4 - LCD D5
;  Bit 5 - LCD D6
;  Bit 6 - LCD D7
;  Myke Predko
;  99.04.28
  LIST P=16C84, R=DEC          ;  16C84 Runs at 4 MHz
  errorlevel 0,-305
  INCLUDE "p16c84.inc"
;  Register Usage
 CBLOCK 0x00C                   ;  Start Registers at End of the Values
Dlay                            ;  8 Bit Delay Variable
Temp                            ;  Temporary Value Used When Sending Out Data
NOTemp                          ;  Temporary Value to "NybbleOutput"
Count                           ;  Character Counter for Output
 ENDC
;  Define Inforation
#DEFINE Data PORTA,0
#DEFINE Clock PORTA, 1
;  Macros
ClockStrobe MACRO               ;  Strobe the Data Bit
  bsf    Clock
  bcf    Clock
 ENDM
EStrobe MACRO                   ;  Strobe the "E" Bit
  bsf    Data
  bcf    Data
 ENDM
 PAGE
 __CONFIG _CP_OFF & _XT_OSC & _PWRTE_ON  & _WDT_OFF
                                ;  Note that the WatchDog Timer is OFF
;  Demo Code, Loop Forever Toggling PA0 (Flashing the LED)
  org    0
  clrf   PORTA
  movlw  0x01C                  ;  Enable PA0 & PA1 for Output
  bsf    STATUS, RP0
  movwf  TRISA ^ 0x080
  bcf    STATUS, RP0
  call   Dlay5                  ;  Wait 20 msecs before Reset
  call   Dlay5
  call   Dlay5
  call   Dlay5
  bcf    STATUS, C              ;  Clear Carry (Instruction Out)
  movlw  0x03                   ;  Reset Command
  call   NybbleOut2             ;  Send the Nybble
  call   Dlay5                  ;  Wait 5 msecs before Sending Again
  EStrobe
  call   Dlay160                ;  Wait 160 usecs before Sending the Third Time
  EStrobe
  bcf    STATUS, C
  movlw  0x02                   ;  Set 4 Bit Mode
  call   NybbleOut2
  call   Dlay160
  movlw  0x028                  ;  Note that it is a 2 Line Display
  call   SendINS
  movlw  0x008                  ;  Turn off the Display
  call   SendINS
  movlw  0x001                  ;  Clear the Display RAM
  call   SendINS
  call   Dlay5                  ;  Note, Can take up to 4.1 msecs
  movlw  0x006                  ;  Enable Cursor Move Direction
  call   SendINS
  movlw  0x00C                  ;  Turn the LCD Back On
  call   SendINS
  movlw  0x040                  ;  Put the Cursor to the Start of CGRAM
  call   SendINS
  movlw  0x030                  ;  Send 6 Characters of 8 Bytes
  movwf  Count                  ;  Output the User Characters
  clrf   FSR
CharLoop
  movf   FSR, w                 ;  Get the Offset to Output
  incf   FSR
  call   ManChar
  call   SendCHAR               ;  Output the ASCII Character
  decfsz Count                  ;  Do 48x
   goto  CharLoop
  movlw  0x080                  ;  Move the Cursor Back into LCD Memory Space
  call   SendINS
  movlw  0                      ;  Display the Man
  call   SendCHAR
  movlw	 'A'			;  Put in "A" for Comparison
  call	 SendCHAR
Loop                            ;  Loop Forever when Done
  call	 LongDlay		;  Delay Between Movements
  movlw	 0x080			;  Send Char "1"
  call	 SendINS
  movlw	 1
  call	 SendCHAR
  call	 LongDlay
  movlw	 0x080			;  Send Char "2"
  call	 SendINS
  movlw	 2
  call	 SendCHAR
  call	 LongDlay
  movlw	 0x080			;  Send Char "3"
  call	 SendINS
  movlw	 3
  call	 SendCHAR
  call	 LongDlay
  movlw	 0x080			;  Send Char "4"
  call	 SendINS
  movlw	 4
  call	 SendCHAR
  call	 LongDlay
  movlw	 0x080			;  Send Char "5"
  call	 SendINS
  movlw	 5
  call	 SendCHAR
  goto   Loop
;  Subroutines
ManChar                         ;  User Characters to Display
  addwf  PCL                    ;  Output the Characters
  retlw  0x00E                  ;  Character 0 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x004
  retlw  0x004
  retlw  0x00C
  retlw  0x000
  retlw  0x00E                  ;  Character 1 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x00C
  retlw  0x004
  retlw  0x00C
  retlw  0x000
  retlw  0x00E                  ;  Character 2 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x00A
  retlw  0x01A
  retlw  0x006
  retlw  0x000
  retlw  0x00E                  ;  Character 3 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x006
  retlw  0x009
  retlw  0x019
  retlw  0x000
  retlw  0x00E                  ;  Character 4 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x007
  retlw  0x009
  retlw  0x018
  retlw  0x000
  retlw  0x00E                  ;  Character 5 - Byte 0
  retlw  0x00E
  retlw  0x004
  retlw  0x004
  retlw  0x00C
  retlw  0x006
  retlw  0x00C
  retlw	 0x000			;  Bottom Character
  retlw  0x01F			;  #### - Note Full Line for Bottom Character
				;  #### - To Show, Comment out the Previous Line
SendCHAR                        ;  Send the Character to the LCD
  movwf  Temp                   ;  Save the Temporary Value
  swapf  Temp, w                ;  Send the High Nybble
  bsf    STATUS, C              ;  RS = 1
  call   NybbleOut2
  movf   Temp, w                ;  Send the Low Nybble
  bsf    STATUS, C
  call   NybbleOut2
  return
SendINS                         ;  Send the Instruction to the LCD
  bcf    STATUS, C              ;  RS = 0
  call   NybbleOut2
  bcf    STATUS, C
  call   NybbleOut2
  return
NybbleOut2                      ;  Send a Nybble to the LCD
  movwf  NOTemp                 ;  Save the Nybble to Shift Out
  swapf  NOTemp                 ;  Setup to Output to the High Part of the Byte
  movlw  6                      ;  Clear the Shift Register
  movwf  Dlay
NO2Loop1
  ClockStrobe
  decfsz Dlay
   goto  NO2Loop1
  movlw  5                      ;  Now, Shift out the Data with the "RS" Bit
  movwf  Dlay
  bsf    Data                   ;  Put out the Gate Bit
  ClockStrobe
NO2Loop2
  bcf    Data                   ;  Clear the Data Bit (which is the Clock)
  btfsc  STATUS, C              ;  If the Bit to be output is a "1", Shift it Out
   bsf   Data
  ClockStrobe
  rlf    NOTemp                 ;  Shift the Next Bit into the Carry Flag
  decfsz Dlay
   goto  NO2Loop2
  EStrobe                       ;  Strobe out the LCD Data
  return
LongDlay			;  Delay 200 msecs
  movlw	 40
  movwf	 Count
LDLoop
  call	 Dlay5
  decfsz Count
   goto	 LDLoop
  return
Dlay160                         ;  Delay 160 usecs
  movlw  256 - ( 160 / 4 )      ;  Loop Until Carry Set
  addlw  1
  btfss  STATUS, C
   goto  $-2
  return
Dlay5                           ;  Delay 5 msecs
  movlw  4                      ;  Set up the Delay
  movwf  Dlay
  movlw  256 - 0x0E8
  addlw  1
  btfsc  STATUS, Z
   decfsz Dlay
    goto $-3
  return
  end
The code's project page:
Two very informative pages concerning the initialization and addressing schemes of the Hitachi HD44780 and compatible chipsets:
CGRAM Tutorials:
Printing Custom Characters on a Character LCD
Hope the info helps in your endeavors,
BigDog
HI
thanks for youre good helps.
LCD controller chipset is TS12864.thanks
The TS12864 is a GLCD and the display's controller is not compatible with the Hitachi HD44780 chipset.
The GLCD controller is compatible with the popular KS0108 chipset.
A project utilizing the KS0108 with routines in PIC assembly:
Some interesting utilities for the KS0108:
GLUtil along with GLSDEMO make it very easy to use a 128x64 KS0108 based graphic LCD display to draw circles, charts, rectangles etc.
GLUtil
Handy Font Bitmap Converter:
GLCD Font Creator 2
There does not seem to be an abundance of assembly routines for the KS0108, however I will keep my eye out for any additional examples.
BigDog
Hi
thanks for youre help.
I have some questions here about GLCD and LCD.
at frist can you give me an example of GLCD with assembly?
if youre answer is no please say to me than what is RST bit on GLCD?and what I must do with that.
I must send some commands to intizaling GLCD or just I must display on it and then set Y,X and then data?(I know how can send data but I don't know what is Z address!!!)
about LCD(CGRAM):
thanks for youre good example but I can't understand some part of it
I can intizaling LCD in assembly and send commands and characters to it.for save data on CGRAM I must send CGRAM address:
movlw 0x40
call LCD_CMD ;LCD_CMD --> send lcd commands
well,now I wanna send my character to save it in CGRAM and then show it on LCD.I understand that if I use this code I can show my character on LCD which is saved in
CGRAM:
movlw 1
call LCD_CHR ;LCD_CHR --> send character to lcd
here,what is 1 ?it was in youre code.thanks
Hi
You might find this code and demo of interest..
  • glcd.zip
You'll need to initialize your KS0108 Compatible GLCD.
I have posted both a KS0108 driver and demo program using the driver. The "initGRLCD" code section in the driver contains the initialization routine for the GLCD.
KS0108 Driver
; Breshenham's line draw for KS0108 based 128x64 LCDs
; (C) Peter Onion 2005
; Use at your own risk !
	Processor       16F877
        Radix   DEC
        EXPAND
        include         "p16f877.inc"
brWleF macro	F,dst
	subwf	F,W
	skpz
	skpc
	goto	$+2		; YUK!
	goto	dst
	endm
#define CNTLPORT PORTB
#define CNTLTRIS TRISB
#define DATAPORT PORTD
#define	DATATRIS TRISD
	;; For 20Mhz use 12.     Can be reduced at lower clock speeds
	;; For 12.288Mhz use 5   Select on test !
#define DELAY 12
	;; Definitions for bits in CNTLPORT
#define CSABIT 0
#define CSBBIT 1
#define DIBIT 2
#define RWBIT  3
#define EBIT   4
#define RESETBIT 5
	;; Definitions for bits in the control word
#define	INCX 0
#define INCY 1
#define DECY 2
#define SETCS 3
#define SETPAGE 4
#define FLUSH 5
#define DONE 6
#define	SAVE 7
	;; Macros for bit twiddling on the control interface
WSTROBE	MACRO
	movlw	12
	movwf	scratch3
	decfsz	scratch3,F
	goto	$-1
	bsf	CNTLPORT,EBIT		; Rising edge
IF 0
	movlw	1
	movwf	scratch3
	decfsz	scratch3,F
	goto	$-1
ENDIF
	bcf	CNTLPORT,EBIT		; Falling edge
					;  strobes data
	ENDM
RSTROBE	MACRO
	movlw	12
	movwf	scratch3
	decfsz	scratch3,F
	goto	$-1
If 0
	movlw	1
	movwf	scratch3
	decfsz	scratch3,F
	goto	$-1
ENDIF
	movf	DATAPORT,W
	ENDM
SETELOW	MACRO
	bcf	CNTLPORT,EBIT
	ENDM
SETW	MACRO
	bcf	CNTLPORT,RWBIT
	ENDM
SETR	MACRO
	bsf	CNTLPORT,RWBIT
	ENDM
SETD	MACRO
	bsf	CNTLPORT,DIBIT
	ENDM
SETI	MACRO
	bcf	CNTLPORT,DIBIT
	ENDM
RESETH	MACRO
	bsf	CNTLPORT,RESETBIT
	ENDM
RESETL	MACRO
	bcf	CNTLPORT,RESETBIT
	ENDM
SELA	MACRO
	bcf	CNTLPORT,CSABIT
	bsf	CNTLPORT,CSBBIT
	ENDM
SELB	MACRO
	bsf	CNTLPORT,CSABIT
	bcf	CNTLPORT,CSBBIT
	ENDM
SELBOTH	MACRO
	bcf	CNTLPORT,CSABIT
	bcf	CNTLPORT,CSBBIT
	ENDM
SELNONE	MACRO
	bsf	CNTLPORT,CSABIT
	bsf	CNTLPORT,CSBBIT
	ENDM
DATA1	UDATA
x1	res 1			; Start ppint
y1	res 1
x2	res 1			; End point
y2	res 1
dx	res 1
dy	res 1
control	res 1
length	res 1
dec	res 1
d	res 1
aa	res 1
bb	res 1
temp	res 1
cachestart	res 1
currentbyte	res 1
cachelength	res 1
count	res 1
pageNo	res 1
AA	res 1
BB	res 1
xpos	res 1
ypos	res 1
ctlCode	res 1			; bits
temp1	res 1
pixelbit res 1
		;; delay	res 1
	;; A cache that hold one "page" of pixels
CacheRam	UDATA
cache	res 64
	;; Scratch registers in shared bank. DO not assume they
	;; are preserved by any subroutines.
	extern scratch1,scratch2,scratch3,scratch4
	GLOBAL x1,y1,x2,y2
line	CODE
	;; Clear the LCD
clearLCD:
	clrf	scratch1	;  set page number to zero
	banksel	CNTLPORT
	SELBOTH			;  Write to both halves together
	SETW
clrloop:
	SETI
	movf	scratch1,W
	addlw	0xB8		;  set page number
	movwf	DATAPORT
	WSTROBE
	movlw	0x40		; set X address to 0
	movwf	DATAPORT
	WSTROBE
	movlw	64
	movwf	scratch2	; counter
	SETW
	SETD
	movlw	0x0		;  clear to OFF
	movwf	DATAPORT
clrloop1:
	WSTROBE
	decfsz	scratch2,F
	goto	clrloop1
	incf	scratch1,F	;  loop until page == 8
	btfss	scratch1,3
	goto	clrloop
	SETI
	SELNONE
	return
	;; Write used part of cache back to the LCD
flushcache:
	BANKSEL	CNTLPORT
	BANKISEL	cache	;  set up for indirect cahce access
	movlw	cache
	movwf	FSR
	banksel	cachelength
	movf	cachelength,W
	movwf	scratch1	;  hold the counter
	banksel	CNTLPORT
	SETI
	SETW
	BANKSEL	DATATRIS	;  reset portd to output
	movlw	0x00
	movwf	DATATRIS
	banksel	cachestart
	movlw	0x40		; set y address to first used
	addwf	cachestart,W	; byte in the cache
	banksel DATAPORT
	movwf	DATAPORT
	WSTROBE
	SETD			; data
	SETW			; write
flushloop:
	movlw	DELAY
	movwf	scratch2
	decfsz	scratch2,F
	goto	$-1
	movf	INDF,W		;  read from the cache
	movwf	DATAPORT
				; strobes data
	incf	FSR,F
	decfsz	scratch1,F
	goto	flushloop
	return
linedraw:
	banksel	ctlCode
	clrf	ctlCode
	clrf	control
	comf	y1,F		; Make y = 0 the bottom rather
	comf	y2,F		; than the top
	movf	x1,W		; check moving left to right
	subwf	x2,W		; and workout dx
	skpnc
	goto	ld1
	sublw	0
	movwf	temp
	movf	x1,W		; swap end points so left to right
	movwf	temp1
	movf	x2,W
	movwf	x1
	movf	temp1,W
	movwf	x2
	movf	y1,W
	movwf	temp1
	movf	y2,W
	movwf	y1
	movf	temp1,W
	movwf	y2
	movf	temp,W
ld1
	movwf	dx		; dx = |x1 - x2|
	movf	y1,W
	subwf	y2,W
	skpnc
	goto	ld2
	sublw	0
	bsf	ctlCode,0	;  Going Up or Down
ld2
	movwf	dy		; dy = |y1 - y2|
	movf	dy,W		; test if steep or shallow line
	subwf	dx,W
	skpnc
	goto	ld3
	movf	dx,W		; swap to make shallow
	movwf	temp
	movf	dy,W
	movwf	dx
	movf	temp,W
	movwf	dy
	bsf	ctlCode,1	;  set "steep flag"
ld3
	clrf	dec
	bcf	STATUS,C
	rrf	dx,W		; W = dx >> 1
	rlf	dec,F		; dec = dx & 1
	subwf	dy,W		; W = dy - (dx >> 1)
	movwf	d		; d = W
	movf	dx,W
	subwf	dy,W
	movwf	AA		; A = dy -dx
	movf	dy,W
	movwf	BB		;  B = dy
	movf	AA,W
	subwf	dec,F		;  dec -= A
	subwf	d,F		;  d   -= A
	movf	dx,W
	sublw	0
	movwf	AA		; A = -dx
	movf	x1,W		; set up for looping
	movwf	xpos
	movf	y1,W
	movwf	ypos
	movf	dx,W
	movwf	length
	clrf	control		; set the inital actions to take
	bsf	control,SETCS	; setup the Chip Selects
	bsf	control,SETPAGE	; set the page number
	bsf	control,SAVE	;
	movf	ypos,W		; Set correct bit in pixelbit
	andlw	0x7		; for the y position
	addlw	0x1
	movwf	temp
	clrf	pixelbit
	bsf	STATUS,C
setyloop:
	rlf	pixelbit,F
	decfsz	temp,F
	goto	setyloop
	;; loop back here if step over to right hand side
setcs:	banksel	control
	btfss	control,SETCS
	goto	pageSet
	bcf	control,SETCS
	btfsc	xpos,6		; set correct Chip select
	goto	setcs1
	banksel	CNTLPORT
	SELA
	goto	pageSet
setcs1:	banksel	CNTLPORT
	SELB
pageSet:banksel	control
	btfss	control,SETPAGE
	goto	initcache
	movf	ypos,W		; set y page address in controler
	movwf	pageNo
	rrf	pageNo,F
	rrf	pageNo,F
	rrf	pageNo,F
	movlw	0x7
	andwf	pageNo,F
	movf	pageNo,W
	addlw	0xB8
	banksel	DATAPORT
	movwf	DATAPORT
	SETI
	SETW
	WSTROBE
initcache:
	bankisel cache
	banksel	cachelength
	clrf	cachelength	; initialise the cache
	movlw	cache
	movwf	FSR
	movf	xpos,W
	andlw	0x3F
	movwf	cachestart
	movlw	0x40		; set x address
	addwf	cachestart,W
	banksel	DATAPORT
	movwf	DATAPORT
	WSTROBE
	clrf	DATAPORT		;  prepare to read from controler
	BANKSEL	DATATRIS
	movlw	0xFF
	movwf	DATATRIS
	BANKSEL DATAPORT
	SETD			; data
	SETR			; read
	RSTROBE			;  Dummy read
readbyte:
	banksel	control
	btfss	control,SAVE
	goto	dontread
	banksel	DATAPORT
	RSTROBE			;  read the byte
	banksel	currentbyte
	movwf	currentbyte
dontread:
	movf	pixelbit,W	;  set the bit
	iorwf	currentbyte,F
	btfsc	control,DONE	; test end flag
	goto	alldone
	clrf	control		;  reset all the flags
	;; DANGER DANGER.....  Check for page boundry !!
here:	banksel	ctlCode
	movlw	high $
	movwf	PCLATH		; page
	movf	ctlCode,W
	andlw	0x7
	addwf	PCL,F
	goto	code0
	goto	code1
	goto	code2
	goto	code3
code0:
	movf	d,W
	brWleF	dec,code01
	movf	AA,W
	addwf	d,F
	bsf	control,INCY
code01:	movf	BB,W
	addwf	d,F
	bsf	control,INCX
	goto	common
code1:	movf	d,W
	brWleF	dec,code11
	movf	AA,W
	addwf	d,F
	bsf	control,DECY
code11:	movf	BB,W
	addwf	d,F
	bsf	control,INCX
	goto	common
code2:
	movf	d,W
	brWleF	dec,code21
	movf	AA,W
	addwf	d,F
	bsf	control,INCX
code21:	movf	BB,W
	addwf	d,F
	bsf	control,INCY
	goto	common
code3:	movf	d,W
	brWleF	dec,code31
	movf	AA,W
	addwf	d,F
	bsf	control,INCX
code31:	movf	BB,W
	addwf	d,F
	bsf	control,DECY
	goto	common
common:
	decf	length,F
	skpnz
	bsf	control,DONE
	btfss	control,INCX	;  did we move to the right ?
	goto	checkINCY
	bsf	control,SAVE
	movf	xpos,W		; increment X
	incf	xpos,F
	xorwf	xpos,W
	movwf	temp1
	btfss	temp1,6		; test for left-to-right change
	goto	checkINCY
	bsf	control,FLUSH	; set flush
	bsf	control,SETCS	; set setCS
	bsf	control,SETPAGE
checkINCY:
	btfss	control,INCY	;  did we move down ?
	goto	checkDECY
	incf	ypos,F
	bcf	STATUS,C
	rlf	pixelbit,F	; move bit
	btfss	STATUS,C	; if carry set, we ned to move to next bank
	goto	checksave
	rlf	pixelbit,F
	bsf	control,SETPAGE
	bsf	control,SAVE
	bsf	control,FLUSH
	goto	checksave
checkDECY:
	btfss	control,DECY	;  did we move up ?
	goto	checksave
	decf	ypos,F
	bcf	STATUS,C
	rrf	pixelbit,F
	btfss	STATUS,C
	goto	checksave
	rrf	pixelbit,F
	bsf	control,SETPAGE
	bsf	control,SAVE
	bsf	control,FLUSH
	goto	checksave
checksave:			; do we need to save byte to cache ?
	btfss	control,SAVE
	goto	checkflush
	movf	currentbyte,W	;  write byte to cache
	movwf	INDF
	incf	FSR,F
	incf	cachelength,F
checkflush:			; do we need to flush the cache ?
	btfss	control,FLUSH
	goto	readbyte
	call	flushcache
	goto	setcs
alldone:			;  write endpoint and flush cache
	movf	currentbyte,W
	movwf	INDF
	incf	FSR,F
	incf	cachelength,F
	call	flushcache
	return
[COLOR="#FF8C00"]initGRLCD:
	banksel	DATATRIS
	clrf	DATATRIS
	clrf	CNTLTRIS
	banksel	DATAPORT
	RESETL			; 5      XX0XXXXX
	SELBOTH			; 0 1    XX0XXX00
	SETELOW			; 4      XX00XX00
	SETI			; 2      XX00X000
	SETW			; 3      XX000000
	RESETH			;        XX100000
	movlw	0x3F		; Display ON
	movwf	DATAPORT
	movlw	9
	movwf	scratch1
	decfsz	scratch1,F
	goto	$-1
	WSTROBE
	movlw	0x40		; set x address to 0
	movwf	DATAPORT
	WSTROBE
	movlw	0xBF		;  set page to 0
	movwf	DATAPORT
	WSTROBE
	movlw	0xC0		;  set display start line to 0
	movwf	DATAPORT
	WSTROBE
	return[/COLOR]
	GLOBAL	linedraw,initGRLCD,clearLCD
	END
Demo Program
	; Created by LCDtrigtable360.c
 	Processor       16F877
trig	CODE
	GLOBAL xtable,ytable
xtable:
	DW 0x40
	DW 0x40
	DW 0x41
	DW 0x42
	DW 0x43
	DW 0x43
	DW 0x44
	DW 0x45
	DW 0x46
	DW 0x47
	DW 0x47
	DW 0x48
	DW 0x49
	DW 0x4A
	DW 0x4B
	DW 0x4B
	DW 0x4C
	DW 0x4D
	DW 0x4E
	DW 0x4E
	DW 0x4F
	DW 0x50
	DW 0x51
	DW 0x51
	DW 0x52
	DW 0x53
	DW 0x54
	DW 0x54
	DW 0x55
	DW 0x56
	DW 0x56
	DW 0x57
	DW 0x58
	DW 0x58
	DW 0x59
	DW 0x5A
	DW 0x5A
	DW 0x5B
	DW 0x5C
	DW 0x5C
	DW 0x5D
	DW 0x5E
	DW 0x5E
	DW 0x5F
	DW 0x5F
	DW 0x60
	DW 0x60
	DW 0x61
	DW 0x62
	DW 0x62
	DW 0x63
	DW 0x63
	DW 0x64
	DW 0x64
	DW 0x65
	DW 0x65
	DW 0x65
	DW 0x66
	DW 0x66
	DW 0x67
	DW 0x67
	DW 0x68
	DW 0x68
	DW 0x68
	DW 0x69
	DW 0x69
	DW 0x69
	DW 0x6A
	DW 0x6A
	DW 0x6A
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6A
	DW 0x6A
	DW 0x6A
	DW 0x69
	DW 0x69
	DW 0x69
	DW 0x68
	DW 0x68
	DW 0x68
	DW 0x67
	DW 0x67
	DW 0x66
	DW 0x66
	DW 0x65
	DW 0x65
	DW 0x65
	DW 0x64
	DW 0x64
	DW 0x63
	DW 0x63
	DW 0x62
	DW 0x62
	DW 0x61
	DW 0x60
	DW 0x60
	DW 0x5F
	DW 0x5F
	DW 0x5E
	DW 0x5E
	DW 0x5D
	DW 0x5C
	DW 0x5C
	DW 0x5B
	DW 0x5A
	DW 0x5A
	DW 0x59
	DW 0x58
	DW 0x58
	DW 0x57
	DW 0x56
	DW 0x56
	DW 0x55
	DW 0x54
	DW 0x54
	DW 0x53
	DW 0x52
	DW 0x51
	DW 0x51
	DW 0x50
	DW 0x4F
	DW 0x4E
	DW 0x4E
	DW 0x4D
	DW 0x4C
	DW 0x4B
	DW 0x4B
	DW 0x4A
	DW 0x49
	DW 0x48
	DW 0x47
	DW 0x47
	DW 0x46
	DW 0x45
	DW 0x44
	DW 0x43
	DW 0x43
	DW 0x42
	DW 0x41
	DW 0x40
	DW 0x40
	DW 0x3F
	DW 0x3E
	DW 0x3D
	DW 0x3C
	DW 0x3C
	DW 0x3B
	DW 0x3A
	DW 0x39
	DW 0x38
	DW 0x38
	DW 0x37
	DW 0x36
	DW 0x35
	DW 0x34
	DW 0x34
	DW 0x33
	DW 0x32
	DW 0x31
	DW 0x31
	DW 0x30
	DW 0x2F
	DW 0x2E
	DW 0x2E
	DW 0x2D
	DW 0x2C
	DW 0x2B
	DW 0x2B
	DW 0x2A
	DW 0x29
	DW 0x29
	DW 0x28
	DW 0x27
	DW 0x27
	DW 0x26
	DW 0x25
	DW 0x25
	DW 0x24
	DW 0x23
	DW 0x23
	DW 0x22
	DW 0x21
	DW 0x21
	DW 0x20
	DW 0x20
	DW 0x1F
	DW 0x1F
	DW 0x1E
	DW 0x1D
	DW 0x1D
	DW 0x1C
	DW 0x1C
	DW 0x1B
	DW 0x1B
	DW 0x1A
	DW 0x1A
	DW 0x1A
	DW 0x19
	DW 0x19
	DW 0x18
	DW 0x18
	DW 0x17
	DW 0x17
	DW 0x17
	DW 0x16
	DW 0x16
	DW 0x16
	DW 0x15
	DW 0x15
	DW 0x15
	DW 0x14
	DW 0x14
	DW 0x14
	DW 0x14
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x12
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x13
	DW 0x14
	DW 0x14
	DW 0x14
	DW 0x14
	DW 0x15
	DW 0x15
	DW 0x15
	DW 0x16
	DW 0x16
	DW 0x16
	DW 0x17
	DW 0x17
	DW 0x17
	DW 0x18
	DW 0x18
	DW 0x19
	DW 0x19
	DW 0x1A
	DW 0x1A
	DW 0x1A
	DW 0x1B
	DW 0x1B
	DW 0x1C
	DW 0x1C
	DW 0x1D
	DW 0x1D
	DW 0x1E
	DW 0x1F
	DW 0x1F
	DW 0x20
	DW 0x20
	DW 0x21
	DW 0x21
	DW 0x22
	DW 0x23
	DW 0x23
	DW 0x24
	DW 0x25
	DW 0x25
	DW 0x26
	DW 0x27
	DW 0x27
	DW 0x28
	DW 0x29
	DW 0x29
	DW 0x2A
	DW 0x2B
	DW 0x2B
	DW 0x2C
	DW 0x2D
	DW 0x2E
	DW 0x2E
	DW 0x2F
	DW 0x30
	DW 0x31
	DW 0x31
	DW 0x32
	DW 0x33
	DW 0x34
	DW 0x34
	DW 0x35
	DW 0x36
	DW 0x37
	DW 0x38
	DW 0x38
	DW 0x39
	DW 0x3A
	DW 0x3B
	DW 0x3C
	DW 0x3C
	DW 0x3D
	DW 0x3E
	DW 0x3F
	DW 0x3F
	DW 0x40
	DW 0x41
	DW 0x42
	DW 0x43
	DW 0x43
	DW 0x44
	DW 0x45
	DW 0x46
	DW 0x47
	DW 0x47
	DW 0x48
	DW 0x49
	DW 0x4A
	DW 0x4B
	DW 0x4B
	DW 0x4C
	DW 0x4D
	DW 0x4E
	DW 0x4E
	DW 0x4F
	DW 0x50
	DW 0x51
	DW 0x51
	DW 0x52
	DW 0x53
	DW 0x54
	DW 0x54
	DW 0x55
	DW 0x56
	DW 0x56
	DW 0x57
	DW 0x58
	DW 0x58
	DW 0x59
	DW 0x5A
	DW 0x5A
	DW 0x5B
	DW 0x5C
	DW 0x5C
	DW 0x5D
	DW 0x5E
	DW 0x5E
	DW 0x5F
	DW 0x5F
	DW 0x60
	DW 0x60
	DW 0x61
	DW 0x62
	DW 0x62
	DW 0x63
	DW 0x63
	DW 0x64
	DW 0x64
	DW 0x65
	DW 0x65
	DW 0x65
	DW 0x66
	DW 0x66
	DW 0x67
	DW 0x67
	DW 0x68
	DW 0x68
	DW 0x68
	DW 0x69
	DW 0x69
	DW 0x69
	DW 0x6A
	DW 0x6A
	DW 0x6A
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6B
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6C
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
	DW 0x6D
ytable:
	DW 0x20
	DW 0x20
	DW 0x21
	DW 0x21
	DW 0x22
	DW 0x22
	DW 0x23
	DW 0x23
	DW 0x24
	DW 0x24
	DW 0x25
	DW 0x25
	DW 0x26
	DW 0x26
	DW 0x27
	DW 0x28
	DW 0x28
	DW 0x29
	DW 0x29
	DW 0x2A
	DW 0x2A
	DW 0x2B
	DW 0x2B
	DW 0x2C
	DW 0x2C
	DW 0x2D
	DW 0x2D
	DW 0x2E
	DW 0x2E
	DW 0x2F
	DW 0x2F
	DW 0x2F
	DW 0x30
	DW 0x30
	DW 0x31
	DW 0x31
	DW 0x32
	DW 0x32
	DW 0x33
	DW 0x33
	DW 0x33
	DW 0x34
	DW 0x34
	DW 0x35
	DW 0x35
	DW 0x35
	DW 0x36
	DW 0x36
	DW 0x37
	DW 0x37
	DW 0x37
	DW 0x38
	DW 0x38
	DW 0x38
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x3A
	DW 0x3A
	DW 0x3A
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3F
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3A
	DW 0x3A
	DW 0x3A
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x38
	DW 0x38
	DW 0x38
	DW 0x37
	DW 0x37
	DW 0x37
	DW 0x36
	DW 0x36
	DW 0x35
	DW 0x35
	DW 0x35
	DW 0x34
	DW 0x34
	DW 0x33
	DW 0x33
	DW 0x33
	DW 0x32
	DW 0x32
	DW 0x31
	DW 0x31
	DW 0x30
	DW 0x30
	DW 0x2F
	DW 0x2F
	DW 0x2F
	DW 0x2E
	DW 0x2E
	DW 0x2D
	DW 0x2D
	DW 0x2C
	DW 0x2C
	DW 0x2B
	DW 0x2B
	DW 0x2A
	DW 0x2A
	DW 0x29
	DW 0x29
	DW 0x28
	DW 0x28
	DW 0x27
	DW 0x26
	DW 0x26
	DW 0x25
	DW 0x25
	DW 0x24
	DW 0x24
	DW 0x23
	DW 0x23
	DW 0x22
	DW 0x22
	DW 0x21
	DW 0x21
	DW 0x20
	DW 0x20
	DW 0x1F
	DW 0x1E
	DW 0x1E
	DW 0x1D
	DW 0x1D
	DW 0x1C
	DW 0x1C
	DW 0x1B
	DW 0x1B
	DW 0x1A
	DW 0x1A
	DW 0x19
	DW 0x19
	DW 0x18
	DW 0x17
	DW 0x17
	DW 0x16
	DW 0x16
	DW 0x15
	DW 0x15
	DW 0x14
	DW 0x14
	DW 0x13
	DW 0x13
	DW 0x12
	DW 0x12
	DW 0x11
	DW 0x11
	DW 0x10
	DW 0x10
	DW 0x10
	DW 0x0F
	DW 0x0F
	DW 0x0E
	DW 0x0E
	DW 0x0D
	DW 0x0D
	DW 0x0C
	DW 0x0C
	DW 0x0C
	DW 0x0B
	DW 0x0B
	DW 0x0A
	DW 0x0A
	DW 0x0A
	DW 0x09
	DW 0x09
	DW 0x08
	DW 0x08
	DW 0x08
	DW 0x07
	DW 0x07
	DW 0x07
	DW 0x06
	DW 0x06
	DW 0x06
	DW 0x06
	DW 0x05
	DW 0x05
	DW 0x05
	DW 0x04
	DW 0x04
	DW 0x04
	DW 0x04
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x01
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x02
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x03
	DW 0x04
	DW 0x04
	DW 0x04
	DW 0x04
	DW 0x05
	DW 0x05
	DW 0x05
	DW 0x06
	DW 0x06
	DW 0x06
	DW 0x06
	DW 0x07
	DW 0x07
	DW 0x07
	DW 0x08
	DW 0x08
	DW 0x08
	DW 0x09
	DW 0x09
	DW 0x0A
	DW 0x0A
	DW 0x0A
	DW 0x0B
	DW 0x0B
	DW 0x0C
	DW 0x0C
	DW 0x0C
	DW 0x0D
	DW 0x0D
	DW 0x0E
	DW 0x0E
	DW 0x0F
	DW 0x0F
	DW 0x10
	DW 0x10
	DW 0x10
	DW 0x11
	DW 0x11
	DW 0x12
	DW 0x12
	DW 0x13
	DW 0x13
	DW 0x14
	DW 0x14
	DW 0x15
	DW 0x15
	DW 0x16
	DW 0x16
	DW 0x17
	DW 0x17
	DW 0x18
	DW 0x19
	DW 0x19
	DW 0x1A
	DW 0x1A
	DW 0x1B
	DW 0x1B
	DW 0x1C
	DW 0x1C
	DW 0x1D
	DW 0x1D
	DW 0x1E
	DW 0x1E
	DW 0x1F
	DW 0x1F
	DW 0x20
	DW 0x21
	DW 0x21
	DW 0x22
	DW 0x22
	DW 0x23
	DW 0x23
	DW 0x24
	DW 0x24
	DW 0x25
	DW 0x25
	DW 0x26
	DW 0x26
	DW 0x27
	DW 0x28
	DW 0x28
	DW 0x29
	DW 0x29
	DW 0x2A
	DW 0x2A
	DW 0x2B
	DW 0x2B
	DW 0x2C
	DW 0x2C
	DW 0x2D
	DW 0x2D
	DW 0x2E
	DW 0x2E
	DW 0x2F
	DW 0x2F
	DW 0x2F
	DW 0x30
	DW 0x30
	DW 0x31
	DW 0x31
	DW 0x32
	DW 0x32
	DW 0x33
	DW 0x33
	DW 0x33
	DW 0x34
	DW 0x34
	DW 0x35
	DW 0x35
	DW 0x35
	DW 0x36
	DW 0x36
	DW 0x37
	DW 0x37
	DW 0x37
	DW 0x38
	DW 0x38
	DW 0x38
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x39
	DW 0x3A
	DW 0x3A
	DW 0x3A
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3B
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3C
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3D
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3E
	DW 0x3F
 	END
shares this code:
    	Processor       16F877
            Radix   DEC
            EXPAND
    	EXTERN initGRLCD,clearLCD,linedraw
    	EXTERN x1,y1,x2,y2
    	EXTERN xtable,ytable
    shared	UDATA_SHR
    FSR_TEMP	res 1
    W_TEMP		res 1
    STATUS_TEMP	res 1
    scratch1	res 1		; work space
    scratch2	res 1
    scratch3	res 1
    scratch4	res 1
    scratch5	res 1
    	GLOBAL	scratch1,scratch2,scratch3
    	UDATA
    count	res 1
    xx	res 1
    yy	res 1
    angleL	res 1
    angleH	res 1
    _ResetVector    set     0x00
    	ORG	_ResetVector
    	movlw	high Start
    	movwf	PCLATH
    	goto	Start
    application CODE
    Start:
    	pagesel	initGRLCD
    	call	initGRLCD
    	pagesel	clearLCD
    	call	clearLCD
    	movlw	0x0
    	movwf	xx
    	movlw	0x3F
    	movwf	yy
    	movlw	21
    	movwf	count
    loop:
    	movf	xx,W
    	movwf	scratch1
    	movf	yy,W
    	movwf	scratch2
    	banksel	x1
    	movlw	0
    	movwf	x1
    	movf	scratch2,W
    	movwf	y1
    	movf	scratch1,W
    	movwf	x2
    	movlw	0x0
    	movwf	y2
    	pagesel	linedraw
    	call	linedraw
    	banksel	xx
    	movlw	6
    	addwf	xx,F
    	movlw	3
    	subwf	yy,F
    	clrf	scratch1
    	clrf	scratch2
    	movlw	0x1
    	movwf	scratch3
    	decfsz	scratch1,F
    	goto	$-1
    	decfsz	scratch2,F
    	goto	$-3
    	decfsz	scratch3,F
    	goto	$-5
    	decfsz	count,F
    	goto	loop
    	pagesel	clearLCD
    	call	clearLCD
    loop3:
    	banksel	angleL
    	clrf	angleL
    	clrf	angleH
    	movlw	60
    	movwf	count
    loop2:
    	pagesel	clearLCD
    	call	clearLCD
    	pagesel $
    	banksel	x1
    	movlw	0x40
    	movwf	x1
    	movlw	0x20
    	movwf	y1
    	call	xsinlookup
    	banksel	x2
    	andlw	0x7F
    	movwf	x2
    	call	ycoslookup
    	banksel	y2
    	andlw	0x3F
    	movwf	y2
    	pagesel	linedraw
    	call	linedraw
    	pagesel $
    	clrf	scratch1
    	clrf	scratch2
    	movlw	0x4
    	movwf	scratch3
    	decfsz	scratch1,F
    	goto	$-1
    	decfsz	scratch2,F
    	goto	$-3
    	decfsz	scratch3,F
    	goto	$-5
    	banksel	angleL
    	movlw	6
    	addwf	angleL,F
    	btfsc	STATUS,C
    	incf	angleH,F
    	decfsz	count,F
    	goto	loop2
    	goto	loop3
    commonlook:
    	banksel	EEADRH
    	movwf	EEADRH
    	movf	scratch1,W
    	banksel	EEADR
    	movwf	EEADR
    	banksel	EECON1
    	bsf	EECON1 & 0x7F,EEPGD
    	bsf	EECON1 & 0x7F,RD
    	nop
    	nop
    	banksel	EEDATA
    	movf	EEDATA,W
    	banksel	angleL
    	return
    xsinlookup:
    	banksel	angleL
    	movf	angleL,W
    	addlw	low	xtable
    	movwf	scratch1
    	movlw	high	xtable
    	btfsc	STATUS,C
    	addlw	1
    	addwf	angleH,W
    	goto	commonlook
    xcoslookup:
    	banksel	angleL
    	clrf	scratch2
    	movf	angleL,W
    	addlw	90
    	movwf	scratch1
    	btfsc	STATUS,C
    	incf	scratch2,F
    	addlw	low	xtable
    	movwf	scratch1
    	btfsc	STATUS,C
    	incf	scratch2,F
    	movlw	high	xtable
    	addwf	scratch2,W
    	addwf	angleH,W
    	goto	commonlook
    ysinlookup:
    	banksel	angleL
    	movf	angleL,W
    	addlw	low	ytable
    	movwf	scratch1
    	movlw	high	ytable
    	btfsc	STATUS,C
    	addlw	1
    	addwf	angleH,W
    	goto	commonlook
    ycoslookup
    	banksel	angleL
    	clrf	scratch2
    	movf	angleL,W
    	addlw	90
    	movwf	scratch1
    	btfsc	STATUS,C
    	incf	scratch2,F
    	addlw	low	ytable
    	movwf	scratch1
    	btfsc	STATUS,C
    	incf	scratch2,F
    	movlw	high	ytable
    	addwf	scratch2,W
    	addwf	angleH,W
    	goto	commonlook
    	END
about LCD(CGRAM):
movlw 0x40
CGRAM:
movlw 1
The "1" represent the custom character you stored in the CGRAM, there is storage in the CGRAM for a total of eight custom characters designated by 0x00 to 0x07, so the example above actually represents the second custom character stored in CGRAM. Also it should be noted that after the custom characters are written in CGRAM a 0x80 command must be issued to return address back to the DDRAM where you can issue a data write of 0x00 to 0x07 to display the appropriate custom character.
BigDog
Reactions: vishy71
    vishy71
