tejashs
hello,
i need a 8 bit dac for my college project,
i saw some DAC's on internet.
But they require a negative power supply. and i need one that works only on +5 volts only
(single supply).
is there any DAC IC(must be easily available). or should i make an R2R ladder DAC using discrete resistors......
which is better......????
the application is not too much dependent upon accuracy, a little error is tolerable i think
(single supply).
