usman_mahfooz
I Am using a hot airgun to heat the IC pad (I apply heat under the IC Pad) which contains vias for underpad heatsink. I am applying heat at 160 Degrees Centi.
The IC is being soldered. But PCB is little deformed. I am using duroid 6002 (20 mil thickness).
Working at 3 GHz, what will be the problems that will arise using above method for soldering.
I HAVE CURRENTLY NO OPTION/FACILITY FOR SOLDER REFLOW OVEN OR WAVE SOLDERING :-|
Only Hot Airgun to solder underpad:shock:. Think of it as a QFN chip with an under pad. What will be the disadvantages to heat the base of PCB to solder top Lumped Components/IC.
Need some ideas and comments
Thankyou
Thankyou
