otakung said:Thank you very much, GhostA.
But in MCS51 family that has only UART, it can set for synchronous mode.
So UART and USART can use both synchronous and asynchronous mode.
Does it mean UART and USART has no differeces except USART can use faster than 115k a little? Thank you. Wink
otakung said:OK, I think I understand.
If the clock is internally generated then it can't be called Synchronous, is it right?
Thank you very much.
otakung said:I know UART only. What is the difference between UART and USART?
Where can I find some information about USART? Thank you very much.
kaustubhkhole said:Can any one suggest any good book for UART..
