patelvijay12007
can anyone provide a schematic and a pcb diagram for pic 16f877a that has a lcd, serial port , pinouts for all ports, icsp of pickit2 and power supply?
The PICDEM 2 Plus board demonstrates the capabilities of Microchip’s 8-bit microcontrollers, specifically, 18-, 28- and 40-pin PIC16FXXX, PIC16F1XXX, and PIC18 devices.
There are a number of Microchip development board schematics available:
... but was looking for more accurate board...
... but the board should have the compatibility to mikroC programmes as well, so that you can use the inbuilt functions directly without much change, althogh picdem2 is a verynice board, it needs more user friendly design, as you can compare with easy pic.I do agree that it quite becomes frustrating when we try complex programmes with easy pic, but then i suppose there must an effective midway between the two...
accurate not feature wise , but the board should have the compatibility to mikroC programmes as well, so that you can use the inbuilt functions directly without much change, althogh picdem2 is a verynice board, it needs more user friendly design, as you can compare with easy pic.I do agree that it quite becomes frustrating when we try complex programmes with easy pic, but then i suppose there must an effective midway between the two...
