karthickb3e
difference between MSP 430 and PIC Controller.
what are advantages of using MSP430
proteus isis a model for the msp430
is available in trail version?
if so what is its version number?
What is LaunchPad?
LaunchPad is an easy-to-use development tool intended for beginners and experienced users alike for creating microcontroller-based applications. At $4.30, the LaunchPad offers everything you need to get started with your projects.
The LaunchPad development tool is a part of the MSP430 Value Line series. The integrated DIP target socket allows all 14 and 20-pin MSP430 Value Line devices to be dropped into the LaunchPad board for easy programming, debugging, and monitoring. Included are free unrestricted and downloadable software development environments for writing and debugging software. The LaunchPad can be used to create interactive solutions thanks to its integrated buttons, LEDs, and extra input/output pins for easy integration of external devices.
Why LaunchPad?
The LaunchPad is an easy-to-use, affordable, and scalable introduction to the world of microcontrollers and the MSP430 family.
Easy-to-use – LaunchPad includes all of the hardware and software needed to get started. Pre-programmed devices and code examples help users get up and running quickly.
Affordable – For $4.30, the LaunchPad includes a development board, 2 programmable MSP430 microcontrollers, mini-USB cable, PCB connectors for expandability, external crystal for increased clock accuracy, and unrestricted software integrated development environments (IDEs) – everything you need to get started today.
Scalable – The LaunchPad is a simple introduction to the MSP430 microcontroller family. As application requirements change, programs developed on the LaunchPad can be migrated to higher end MSP430 devices.
i am using msp 430fg2211 and msp430x2xxx series for other projects
c/c++
using of code composer studio version 4
