markotech
Newbie level 5
I have built several square wave and modified sine wave inverter, but still have challeges which i want help before i start experimenting switch mode sinewave inverters;
my challeges are;
1. my output is not as good as those commercial modified sinwave inverters, this is very obvious when using ceiling fan;
2. when i plug computer system the voltage swing up to over 300volts;;
please i need help can somebody help me with a good modified sinewave 50hz inverter circuit; pls you can send to my email; "markotech2020@gmail.com" thanks
my challeges are;
