vikasvij1982
Newbie level 5
I have a design which deals with 100's of paths on which i set min/max delays and i would like to know if Design Compiler has any command which actually only gives me the violators out of all these paths. e.g. Suppose say i have path 1, and 2. I individually synthesize path1 and it works. Suppose path2 is added in the list of constraints and path2 optimization happens before path1. If path2 constraints are not met then design compiler exits optimization and since path1 has not been optimized, i get a negative slack for path1 also even though it should not report a negative slack. Hence if i have 100 paths then it is not possible for me to check and optimize each path individually first and then combined. Hence if there was a method which did not stop design compiler when path2 got violated and optimized path1 also then it will be helpful.
Vikas
Vikas
