jianhuachews
![Member level 2](/styles/images/ranks/dlevel2.gif)
Hi guys.. Can anyone help me to look at the problem..? Modelsim gave me this error on my test bench..
While my program code can be compiled... i don't know what's wrong!!
program
Testbench
Thanks in adv!
# ** Error: C:/Users/Chew/Desktop/columncounter tb.vhd(20): Signal "col_out" is type ieee.std_logic_1164.STD_LOGIC_VECTOR; expecting type ieee.NUMERIC_STD.UNSIGNED.
program
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
entity column_counter is
port (
col_out : std_logic_vector(3 downto 0);
rst : in std_logic;
clk : in std_logic
end column_counter;
architecture Behavioral of column_counter is
signal temp : std_logic_vector(3 downto 0);
begin
process(clk)
begin
if(rising_edge(clk)) then
if(rst='1') then
temp <= (0=> '0', others => '1');
else
temp(1) <= temp(0);
temp(2) <= temp(1);
temp(3) <= temp(2);
temp(0) <= temp(3);
end if;
end if;
end process;
col_out <= temp;
end Behavioral;
Testbench
library IEEE;
USE IEEE.std_logic_1164.ALL;
entity column_counter_tb is
end;
architecture behavior of column_counter_tb is
--Inputs
signal rst: std_logic:='1';
signal clk: std_logic:='0';
--Outputs
signal col_out: std_logic_vector(3 downto 0);;
-- clock period definitions
constant clkperiod : time := 20 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: entity work.column_counter port map(
col_out => col_out,
rst => rst,
clk => clk);
-- Clock process definitions
clkprocess :process
begin
clk <= '1';
wait for clkperiod/2;
clk <= '0';
end process;
-- Stimulus process
stim_proc: process
begin
rst <= '1';
wait for 70 ns;
rst <= '0';
wait for 140 ns;
rst <= '1';
wait for 200 ns;
rst <= '0';
wait;
end process;
end;
Thanks in adv!
