kudjung
Member level 4
Hi Folks,
I've been playing with LTspice simulation and done coorelation with basic lab equipment with some help form the expert on this forum. It been a while since I have a chance to review this basic stuff. This is very useful.
I'm stuck with one issues. I attached 2 file here. One result is from AC Analysis and another is from Transient Analysis. I did the transformer simulation using 2 method, one is using LTspice coupled transformer model and another is using a T model calculated from transformer datasheet.
On Ac analysis, the result are as I expect for both method and quite coorelate between the 2 models.
On Transient analysis, result from coupled inductor method seem to look ok but the one with T-Model are strange. Can anyone explain why I got this result when I use the T-model. I've a feeling that I probably missing something very easy.
BTW, I've another few questions with LTspice if someone happen to know the answer.
-How to attached the cursor to the phase plot in AC analysis?
-Is there a way to save plot and reload it later? I want to be able to see the result of transient analysis and AC analysis at the same time.
TIA,
TIA,
