matlab code for ifft calculation
ashumtech
Junior Member level 1
I am doing a project on signal processing in which i have to find ifft of band pass signal(2-10 GHz). normal code is working for low pass signal only.
kindly suggest some modification
Hi ashumtech,
you can treat your signal like a low-pass one (0 to 10 GHz).
Simply, that 20% of unused spectrum will be zero.
Z
