yyyyaser
Newbie level 5
Hello
This is my first mc project , but the mc is not working , I tried every thing and searched the internet for hours , could the mc be damaged because of some error I could've done , knowing that the micro is recognized by the programmed , and I tested the code on proteus and it worked fine .
also , when I save a certain hex file to the micro then load the micro contents to another hex file , the two files contents are similar but not identical , could that be the problem.
one more thing , I have a bad feeling that I can't get things together , I didn't find a good source to have a solid knowledge about how to use the micro , how to connect it , how to program it using mikroC pro , when to use SFR and when to use mikroc library fns , what are the default pin configuration and how to change it (I have seen the micro datasheet and it wasn't very helpful) , if someone knows such source , please tell me.
thanks in advance
thanks in advance
