themaccabee
Full Member level 4
I was going through the datasheet of NE566 IC .
There is a control voltage Vc to control the frequency of oscillation.But in the datasheet it has been specified V+≦Vc≦V+ where V+ is the input voltage..
I couldnt understand the same.
Also it has been mentioned the absolute maximum voltage to the Vc pin is 3Vpp
Can some body help me to understand the same?
