jpanhalt
Advanced Member level 3
At 10V Vgs, the IRF3205 will be turned on. You can check in the datasheet what its expected Rds will be at whatever current (Id) it is conducting. At this point, I am not sure I understand the question you are asking.
From my understanding so far, you want to used multiple, low-cost mosfets in parallel to control 100A at 24V. We don't know whether that load will be continuous or whether it is inductive, resistive, or capacitative. There has been some uncertainty about terms in the datasheet. Heat will be a major consideration, and I believe you will have better success using a commercial mosfet driver rather than trying to design one yourself.
Here are some additional links that may help you:
**broken link removed** one deals with interpretation of the thermal/heat characteristics described in the datasheet.
This one from Microsemi is more general and describes how to interpret a mosfet datasheet.
John
John
