[SOLVED] A question about Instruction memory and data memory
yushionly
Junior Member level 2
In MIPS CPU architecture, we know there are instruction memory and data memory,I do not understand whether they are both SRAM,and if yes, are they the same Sram?Thanks
Instruction Memory and Data Memory act as Cache for providing fast access. Normally Cache are made up of SRAM. So most likely, Instruction Memory and Data Memory are SRAM
thanks for your help!
---------- Post added at 16:21 ---------- Previous post was at 16:16 ----------
thanks for your reply!
Except Instruction memory stores instructions while Data Memory stores datas,are there any other differences? Like control signals,for example,clk,readmem,writemem,datain,dataout?
