jdm programmer with winpic800
alaalwi11
Al khurtum-Sudan
hi all ihave porblem in program pic contrller gave me headache for along time
problem is that the programer can not able to detect the pic
when the detected led in programer is light
i work with serial port
pls help me
Hi:
I had a similar problem with Winpic800 using the serial port. The problem was solved by soldering 33pF ceramic capacitors from PGC, PGD and Vpp to GND.
change the burner program use ponyprog.i had the same problem.did you search forum ? There are a lot of topic related it .i am sure you will get the solution .best of luck
Are you using a laptop or a desktop....? this type of programmer will not work in laptops..... also check whether a voltage of 11.9V appears at pin 1 of zif socket during read/write operation without inserting IC.....
If its your first time don't use a JDM type programmers as these programmers ,obtain their power form the RS232 signal line, some times it is possible as the standard RS232 signal swings between -12VDC to 12VDC so the MCLR i.e.. Vpp can be obtain from this voltage level ,but not all chips use these RS232 standards ,like in laptops and in many PC they use a low power and with lower voltage levels for power saving (energy efficient chips),in this case your JDM will not work.
So you can go for Parallel Port or Serial Port programmer with external power supply..here is two link use the software provided with them.
Serial Port Programmer : Serial Port PIC Programmer
Parallel Port Programmer : Parallel Port PIC Programmer
Good luck
SERIAL jdm programmer with winpic800
This one a Serial JDM PROGRAMMER
SCHEMATIC AND DETAILS
CONFIG with WINPIC18F4550
