[SOLVED] Reset circuit explanation for EM6325
nikhillife11
Hello friends,
Can anyone explain me how this circuit in the attachment works. Why are we using c2 and why is C1 connected in reverse mode.
Please explain in simple words.
Thanks and Regards
Nikhil
It seems that C2, R1 and Q1 prevent from pushbutton bouncing.
R2, C1 and the internal pull-up of manual-reset input determine the reset pulse duration once the pushbutton was pushed down.
D1 clamps the reset input when C1 discharges through R2.
IMHO this circuitry may be useless due to the EM6325C has internal debouncing, so all you need is connecting the pushbutton from GND to the manual reset input.
The only difference should be that, in the last case, the reset output will keep active until you release the pushbutton.
Regards,
Regnum
What if I remove that push button.Actually i have another circuit without that push button too. But it doesnot make sense for me to use a transistor before a reset circuit... An why C1 is reverse baised. As i know if you reverse bais a capacitor it will get blown up.
Plz some more guidance.
Nikhil
Yes, you may remove the pushbutton and all the circuitry around it, but manually reset will not be possible.
C1 is not reversed.
If you take a look at the datasheet of the EM6325, you'll find an internal pull-up resistor in the manual reset input, so that when Q1 is "ON" the minus pin of C1 falls to ground, and the plus pin of C1 is tied to VCC through the internal pullup. When Q1 is "OFF" both minus and plus pins are connected to VCC through R2 and pull-up respectively. D1 gives C1 a discharge path when Q1 switch to OFF, clamping the manual reset input to [VCC + VD1forward].
Regards,
Regnum
Hello Regnum,
Thanks for the reply,but i have some more querys.Since,when Q1 is "ON" the minus pin of C1 falls to ground, and the plus pin of C1 is tied to VCC through the internal pullup. then how does MR(Low) gets active. In both cases,It will have some voltage at it pin.
Do reply.
Nikhil
When Q1 switchs to ON the plus pin of C1 also falls to ground, and goes progressively to VCC as C1 is charging through the internall pull-up.
