yasir23
![Member level 1](/styles/images/ranks/dlevel1.gif)
this ckt is working.but problem is that its not showing correct level of water at seven segment display at the run time until i pressed the reset button. when i pressed the reset button so it show the correct level of water but buzzer will start sound then i dip the lower limit of sump then the buzzer gets off.
plz help i want to implement in my house.
ckt in attach doc![untitled.JPG untitled.JPG](https://www.edaboard.com/data/attachments/6/6940-e8bb570af50ef35c55b04909e83c8bac.jpg)
ckt in attach doc
