speed controller for asynchronous motor
_SOFY_
I want to vary the motor speed automatically using position sensor, I don't know how to use the microcontroller for automation.
help plzz
Do you want to turn a knob clockwise to increase the speed of an async motor from 10 rpm to 1500 rpm?
Reactions: _SOFY_
    _SOFY_
No the motor turns a mechanism, I use two position sensors to increase speed, the first detection sensor will increase the speed to 70% and the second at 100%.
Start by looking here: **broken link removed**. That will give you some information on controlling various types of motors.
Most easy way is to use inverter module
with 2 inputs for fixed speed. ( set with parameter or potentiometer )
Need only make connections and set few parameters and it`s done.
try google " motor inverters "
for exmpl.
Regards KAK
