pcb layer printing in Altium
proyex
hi, i need to print the artwork of my pcb design, because i want to make my pcb with PCB transfer film paper, os i only need to print bottom layer and later a second printing of top layer, question is how i do this, because when i print, all layers are printed
i use altium summer design 09
thanks
file -> print preview then right click and "configuration". finally right click for the insert layer or delete layer....
Reactions: proyex
    proyex
thank you very much, its ok
check for the scaling of your design you have to set scale to 1:1 while printing directly from PCB I would rather suggest you to print it through CAM tool (CAMTASTIC).
