Circuit Pic16f877 / thermocouple K / ad623 problem
Zwilorg
Member level 5
Member level 5
hello,
i am here to ask how can i get the thermocouple type K working with an AD623 opamp!
i have the program on the pic16f877 working without any problem i believe...
i used the Potenciometer (RV5) connected to AN0 for posterior conversion of data from analog to digital, just for testing...
i never thought i would have so much problems getting the data from the thermocouple....
Can someone check my circuit and see what is wrong in the build of the opamp?
Everything else is right and tested :p so just focus on the AD623 and the thermocouple
In this picture i used the REF on AD623 as +2.5V just to see what it would give as a result... i used ground also...
I also read that i could use max6675 more easilly than add623 but the maximum temperature it reaches is 1024C is this true?
PHP:
http://dl.dropbox.com/u/2769457/ad623.png
what is the range of voltage difference across the thermocouple?
Why you are not using AD595?
When you are using opamp you should care about its input and output offsets and drifts VS ambient temperature.
After that you should compensate reference (or cold) junction temperature in your PIC.
The AD595 do all this works! The AD595 have an amplified and compensated output that you can use in your circuit.
i am using a type k thermocouple made with Nickel-Chromium,
so the range is from
0ºC -> 0.0mV
to
1250(close enough) -> 48 or 49mV
---------- Post added at 16:56 ---------- Previous post was at 16:49 ----------
i am still not very confortable working with opamp! i will read some more and try to make it work with the ad595.
i was using the ad623 cause it was pointed out to me.... :S
Thank you for your input!
What voltage are you seeing at the output of the opamp at room temp?
Hi Zwilorg
I insert the Voltage-Temperature table of type K.
  • z204-206.pdf
I recommend you to using AD595(for type K) or AD594(for type J) or LT1025(for types E, J, K, R, S, T) rather than using thermocouple output directly(i.e with an amplifier).
The output of AD595(in case of using type K) is directly proportional to Hot junction temperature. But if you use thermocouple output directly, you must measure ambient temperature to compensating reference temperature. such operation causing many error on measuring Hot junction.
---------- Post added at 18:11 ---------- Previous post was at 18:09 ----------
Also you can recalibrate AD595(or AD594) for any type of thermocouples.
There are application notes about cold junction compensation.
  • Cold Junction compensation.zip
Thank you all for the help!
i am sorry for not answering before.
I tried making it work with the ad595 and it finaly read something on the simulator :wink:
it was as followed:
https://obrazki.elektroda.pl/43_1302708799.png
but the numbers reading over the rs232 and the lcd are all messed up...
i did the following on the MPLAB, hitech compiler
short int adc_res;
short int temp_c;
const double res=14.59;
adc_res =(((unsigned int)ADRESH)<<8)|(ADRESL);
temp_c=(adc_res*(short int)res)/10;
or
temp_c = 5 * (float)adc_res / 1023 ;
neither worked properly...
many thanks for all the quick help!
Which compiler you are using?
I think that "Short int" is an 8bit integer while you used it for holding a 10bit ADC result.
---------- Post added at 09:40 ---------- Previous post was at 09:32 ----------
Zwilorg!
Note that AD595 amplifies and compensates the thermocouple output but does not correct the nonlinearity of thermocouple output!
It's better to first measuring the output voltage of AD595 and then convert it to temperature by using type K "VT" table.
---------- Post added at 09:45 ---------- Previous post was at 09:40 ----------
Of course it's not applicable if you want to store all of the data in "VT" table in a MCU. Instead you can divide the "VT" table in a few part and assume a constant Temperature coefficient for each part.
Zwilorg!
how can i do that?
is it a floating table?
and btw is the circuit built properly? i just copied it from the app notes ^^
Another way is to convert measured voltage to temperature by using formula.
---------- Post added at 09:54 ---------- Previous post was at 09:46 ----------
You can test your circuit by using a voltmeter. in 25C the output of AD595 should be about 250mv.
See this for VT table and formula:
  • Type K.txt
this was exactly what i was trying to do! i believe that although the formula is right, the circuit or the conversion bit of the adc (adc_res =(((unsigned int)ADRESH)<<|(ADRESL);) are wrong!
but i just don´t know which. i really never thought i would get stuck in this part hehe
Also for more information about thermocouples, VT tables and conversion coefficient see "www.srdata.nist.gov"
---------- Post added at 10:03 ---------- Previous post was at 10:01 ----------
If you get a 250mv (in 25C) output from AD595, then every things is OK!
---------- Post added at 10:11 ---------- Previous post was at 10:03 ----------
Define adc_res as Unsigned int and try again.
tried that ;) but it is srdata.nist.gov with the "www." it goes to a 440 thanks ;)
i am getting now for:
unsigned int adc_res;
adc_res = (ADRESH<<2) + (ADRESL>>6);
and output of adc_res=102
and with
and output of adc_res=6654
Try this:
adc_res = (ADRESH<<8) + ADRESL;
exactly the same output as
maybe the error is on the circuit i posted above with the ad595?
I simulate your circuit, the output of thermocouple is exactly 1.000mv(in 222C) but the output of AD595 is 2.48. in simulation the output of AD595 have about 250mv offset.
