HSPICE Question, For/While Loop
MammPp
Junior Member level 2
Hi all,
I tried to model the circuit which required the repeat calculation such as
Resistor in out R = A*10
Where A is calculated from the other equations such as
A = V(in,out)+step*I(Resistor)
When the parameter A is updated, the resistance will change and parameter A will update again then the resistor would change again and so on.
From this point, I tried to use for loop within the HSPICE.
Someone recommend me about using the C programming and update the script. However I wondered that is there any more simple method than above ?
Thank you for your help
MammPp
I have done a similar thing using perl script. There is a code available for this. This code rewrite the hspice netlist for the given value of some parameter ("R" in your case) and then extract the output from the output file of hspice. You can modify the code according to your need.
Reactions: MammPp
    MammPp
Thank you himansg
:D
Can someone reupload the code? The site doesn't exist anymore
