vibration problem with accelerometer
welove8051
Full Member level 6
Full Member level 6
india
dear dudes, i try to built a self balancing robo with 89s52 and mm7260qt accelerometer. the sensor is working fine, the problem is the sensor is responding to even small vibrations from motors and others, which makes reading unstable and so i am unable to balance it, how do i solve this problem. is 89s52 and adc0804 is capable for this project, pls do share your experience and suggestions.
regards
kj
:roll:
Two possible ways come to mind -
a rubber mounting to minimise those vibrations plus running the reading though an x16 or greater averaging routine to do the same.
I think a low pass filtering of the signals from the accelerometer will do it. Are you currently using low pass filter?
you need to implement a low pass filter since an accelerometer is a noisy module itself. this can help why: **broken link removed**
