[SOLVED] How to ensure correct symmetric component orientation?
bobsun
Full Member level 2
Full Member level 2
I would like to ask a question on symmetric component orientation.
Most of the components are symmetric at least in one dimension, and most chips are square. For things like this, how can we ensure that they will be soldered in the correct orientation, when they are not soldered by machines out of tape and reel, but in prototyping by manual soldering?
For example, the attached picture show a component whose pin arrangement is:
1 6
2 5
3 4
But after rotating \[{180}^{o}\] , they become
4 3
5 2
6 1
And if soldered in this way it will surely cause the system to disfunction.
So how could I prevent this from happening? Do I have to stand beside the solder worker and checking with component’s orientation from my laptop, and point out the right orientation?
Bob
Put a legend on the board that identifies the correct orientation, or provide an assembly drawing that shows it.
And train the assembly operator to do it correctly.
Reactions: bobsun
    bobsun
Add pin1 marker on the PCB. inside & outside is better especially for prototyping.
The circle inside is the reference for the pin 1. The triangle outside is also a pin 1 marker which will be helpful in debugging if the component is already mounted.
Reactions: bobsun
    bobsun
What is "inside & outside"? Do you mean putting the marker on both top and bottom layer?
Bob
---------- Post added at 09:26 ---------- Previous post was at 09:25 ----------
Mattylad,
Could you show an example?
Bob
I placed an image on my last post. Circle marker is inside the component & Triangle marker is outside the component.
-KAK
Reactions: bobsun
    bobsun
Dear KAK,
I see lots of blue and yellow crosses in your picture. Do they indicate power plane connection (different color for different planes)? I am using Altium Designer which also have such crosses so I would like to know if it is the same in your software.
And the silkscreen layer in your software is red?
Bob
---------- Post added at 09:48 ---------- Previous post was at 09:47 ----------
Dear NIKHILRAJ,
Great, I got it.
Bob
Dear KAK,
Bob
Yes, you can set different color for different plane. Yes my silkscreen layer is red. Altium & PCAD is almost the same. its just that Altium is more capable on doing other things than PCAD. PCAD is a discontinued product from Altium.
-KAK
Reactions: bobsun
    bobsun
Dear KAK, NIKHILRAJ and Mattylad,
What about for BGA components?
First, BGA components pins are not usually ordered as 1, 2..., but is alphanumerical combination like A1, A2...B1, B2..T1, T2..., so how do we mark?
And does BGA components (chips) have any indicator on them so they can be matched?
Bob
Again pin1 marker inside & outside works for me. a small triangle on the edge for the inside & a large triangle outside.
Yes all BGA have a circle placed on the corner indicating the pin A1.
-KAK
Reactions: bobsun
    bobsun
BGA ic have A1 indicator on it. You just need to put some marking in the silkscreen and assembly as in the case of SOIC.
IPC recommendation is a circle outside the componet and triangular chamfer inside
Reactions: bobsun
    bobsun
You have "an indication" of a polarisation of components.
Like you have a line at the end of a diode, or a + mark etc.
Whatever you come up with simply show your assemblers and train them to think smart, to understand how the components go.
Draw an assembly drawing to help them.
Give them nothing, tell them nothing and get back a PCB that is worth nothing (because it does not work).
Reactions: bobsun
    bobsun
Dear KAK and NIKHILRAJ,
Many thanks for the attached picture. I fully understood it.
Bob
