TO220 package or TO-220 Full Plastic Package which is Better
saumya_85
Full Member level 1
INDIA
I have two packages of N MOSFET, TO-220 package and TO-220 Full plastic package.
Which one is better in terms of reliability with max. temperature environment.
Thank you.
Slightly better thermal conductivity has the basic TO220 package, but I wouldn’t worry much about that issue, MOSFETs in both packages when mounted on a proper heatsink work just fine ..
The plastic version has one important advantage, that is it doesn’t need mica or Teflon insulation washer and bush ..
IanP
:wink:
Could you explain more details on packages for the below two parts.
Regarding the selection of IRGB10B60KDPBF which is TO-220 package or IRGIB15B60KD1P which is TO-220 Full plastic package, Which one should be considered.
Thank you
Plastic package gives you the comfort of not using washers and bushes, go for them ..
IanP
:wink:
