Kaleborg
Member level 4
I'm uncertain about one thing and hope somebody here can clear it out for me.
I need to connect two uC together, one is PIC18F working on 5V and the other one is M16C working on 3.3V. My question is it ok to simply connect them together or do i have to use some level shifting or simple resistors will do.
The M16C can work on both 3.3v and 5V but in this particular case its operating on 3.3V. Datasheet says that voltage on pins can be Vdd+0.3V so in this case max voltage would be 3.6V but since it can operate on 5V i suspect that i can connect it directly to 18F.
Thanks in advance
Thanks in advance
