[SOLVED] Problem on understanding Sentaurus TCAD Flow
Avenger888
Newbie level 3
Newbie level 3
Malaysia
I have problem regarding the understanding of using Sentaurus TCAD software.
How do i want to use the Sentaurus Workbench if I want to get a Id-Vg curve of nmos (for example ) by using Sentaurus Structure Editor. (no sprocess, no ligament)
I guess you don't need to use WorkBench then. Just create your structure in the editor (or write a script, which should include also information about the mesh), save it as an .scm file and run 'sde -e -l yourfile.scm'. Afterwards, all you need is to create a simulation command file that will load the previously created structure and run 'sdevice yoursimulation.cmd'. More info about creating the scripts can be found in Sentaurus manuals - they also contain some examples.
