Allegro PCB editor- Routing
Prince Moses
Bangalore
hi mate..
i am using allegro pcb editor 16.2 version. while routing through one via, i m facing problem that already routed line through the same via get deleted. So, is there any restriction that one via should have limited number of connections?? if so, plz suggest me... thank u so much..
Prince Moses
hi,
option-replace etch should be in off..if its on the already routed line gets deleted
