2*16 LCD programing.....
mannoooj
Newbie level 5
Newbie level 5
Hello .....
I need help in 2*16 LCD programing.....
I want to display some text on 1st line continuously and want to vary text on 2nd line as per requirement.
Thank you
you write a function which will display text on a specified line, e.g.
// write string on line (1 or 2)
void lcdString(unsigned char line, unsigned char *string);
then call it with the line 1 or 2 as required
Your LCD library probably has a "gotoXY" function (check your library) ,
you can use it to go to a specific line/char position and then use the "lcd_putchar" function (again check your library for the correct name) to write what you want.
Alex
check this tutorial might help: **broken link removed**
