sapna.dudani@gmail.com
Member level 4
- Joined
- Feb 14, 2011
- Messages
- 78
- Helped
- 23
- Reputation
- 46
- Reaction score
- 23
- Trophy points
- 1,288
- Activity points
- 1,890
hey dear friends..
I am a beginner in electronics project and m stucked in some silly basic questions.. please help me out..
I have to connect my 7 segment display to my microcontroller i.e. of pic16f series.. with source and sink current being 25 mA, and the forward current of my led is 20 mA, of 1 digit and i m using 4 digit 7 segment led .. how do i connect the led to my microcontroller
I know i need to add a device to decrease the current from led as they are 4 digits each carrying If = 20 mA... so as to protect the microcontroller, wat will be the difference if i use a resistor or a shift resistor... and wat else can i use here...
its a common cathode type led... i am also facing problem in connecting the enable pin there are total 10 pins in my 7 segment led 7 pins for 7 segments , 1 pin for dot and 2 enable pins.. how do i connect the two enable pins to my microcntroller..
here i googled and found out that i can use a transistor and a resistor to each enable pin separately which 'll go to microcontroller but then which type of transistor and how shall i connect it ..
what parameters shall i go through ... please help me out...?
if possible can anyone send me a link to any article related to the internal structure of a 7 segment display both common cathode and anode type.....
awaiting response...
dont use sms format typing or short hand typing scripts in the forum..
this will lead to deletion of post and inviting infraction
