Help me draw a helical coil in HFSS
tketke2002
Helical in HFSS
I am planning to analyse some antenna structure including a helical coil. However I know this is basic I am not able to draw the coil in HFSS.
Can anyone guide me ?
Thanks in advance,
Tony
Helical in HFSS
use vbs .but i do not know the detail
Reactions: orle
    orle
Re: Helical in HFSS
hi:
you should just go to the line menu and draw easily your coil cross section with one of the (triangle rectangle circle or other giometrical strauctures) and then go to solid menu and choose the helix option and then select your cross section and turn it around one of coordinate axis with desired pitch and radious and so on .
regard.
Re: Helical in HFSS
hi:
regard.
i m phasing the same problem how to design helical antenna for 12 GHz and how to calculate pitch
Re: Helical in HFSS
For drawing the Helical Antenna, in HFSS from the main menu, you can choose:
Draw -> User Defined Primitives -> SysLib -> SegmentedHelix
Another way to design it would be using Antenna Design Kit provided by Ansoft. That makes it really easy and it can be obtained from their website.
As for calculating the pitch, it really depends on the characteristics of your antenna and whether you want the antenna to operate in normal(broadside) mode or axial(endfire) mode. For normal mode changing the pitch value results in the antenna changing from being circularly to elliptically polarized to linearly polarized. For axial mode, pitch should be large fraction of the wavelength to achieve circular polarization. One suggestion would be to have the pitch equal to quarter wavelength for axial mode.
I hope this helps.
Joline
:grin::grin::grin:
  • helix.hfss.rar
