I am assuming you have downloaded and installed the PSoC Designer SW that is the IDE for that microcontroller. That IDE has a "catalog" of user modules, which are basically configurable drivers for the peripherals on the device. If you want a simple timer, look in the "Timers" section of the catalog. Choose one, add it and place it into your project, and then read the datasheet for the user module you are using. The datasheet should have example code and all information necessary for using the timer user module you have selected.
Another helpful link to the Cypress Forum: Cypress Semiconductor
There are many very knowledgeable people here on edaboard but the Cypress forum is specific about PSoC.
Just a recommendation.
Most of your questions would be best posted under "PSoC Software" "Designer"
hth Bob
